re cam run in
re cam run in
i have a emw h cam with a recomended spring preasure if 165lbs
i am a bit woried about runing the cam in with that much seat preasure .
i don't want to flaten out the cam .
i am wondering if its a good idea to reinstall the singles the heads came with
to run the cam in ,then put the duals back in or even tacking out the inner spring of the duals to run it in
Re: re cam run in
After you wipe a cam, the cam sellers will ask you how you did it, and tell you the other way was right
Give them a call first and ask if in any doubt, our opinions do not count for warranty purposes.
Run it in as-is with a good high ZDDP oil (preferably proper break-in oil) and the EP cam assy lube junk and the springs you are going to use unless the cam seller specifically tells you otherwise first.
Keep the RPMS over 2000 and vary the speed some if you like above that.
If its going to fail, its going to fail.
You don't want to be cranking on it for half an hour, jack in a known working ignition and fuel setup if possible.
- craigvwdude
Re: re cam run in
a lot of guys will break a cam in with just the outer springs and then add the inners after break-in is done. I have done this also. Is it really needed? I don't know but it does give you piece of mind that first 20-30 minutes of its life.
Re: re cam run in
Never happened to me so I guess I'm blessed, but the horror stories you hear definitely support that statement.Piledriver wrote:After you wipe a cam, the cam sellers will ask you how you did it, and tell you the other way was right
Breaking in with lighter springs is sensible, but normally isn't a necessity if you follow all of the good advice above.
Re: re cam run in
thanks for the replys
i have email emw last week with no reply but with xmas a day away i
probo;y left it to late
i will try and email them again
i have run stock vw cams in,as well as a few big chevy cams where i have taken the inner spring out
Re: re cam run in
EMW answers the phone, email not so much.
Re: re cam run in
Merry Christmas everyone
Damo this is the EMW phone number including all codes from Australia , 0011 1 310 644 8038 . also I think Penrite HPR 40 has the highest level of zinc that I've found (1500 ppm)
1 use Hpr 15 synthetic (1200ppm) and have 100k on my 71mm by 103mm no issues ,! just replaced the big ends doing a top end overhaul , the cam(wade Hydraulic GTR XU1 grind) looks good as does the crank journal just replaced the bearings because their cheap. I've multiple coolers and a thermostat and like to keep the oil temps below 95C .
What did you end up doing for a crankshaft?
cheers Derek
cheers Derek
Re: re cam run in
thanks derek for the phone # i will try and ring in the new year .
i ended up getting a AA crank , it looks ok
Re: re cam run in
just got an email from emw .
they recomended running cam in with singles then reinstaling the duals
damo
damo
- Type 4 Unleashed
Re: re cam run in
Have you done the break-in yet ?
They were referring to running the outer single spring of your dual springs to break in the cam, then adding the inner spring after broke in.
You can not use the stock single springs to break in your cam, they will not handle the lift of the cam and will coil bind.
Richard
EMW
EMW
Re: re cam run in
]Type 4 Unleashed wrote:Have you done the break-in yet ?
i was going to use the outers only for break in then reinstall the inners
i havn't done the break in yet just finishing of the install at the moment
