Type 4 80*106 .... 2825cc
Posted: Fri Aug 22, 2014 3:11 pm
by coxcarrera
After a 80*103mm sold
, 86*107mm sold
...... The new evolution 80*100 and 80*102 , NOW
80*106
The engine specs :
Type 4 Case
Scat 80mm old new polished
Pistons 100mm ultralight
Porsche cylinder 100mm (3.6L 6cyl) nikasil mahle
T.Pieper Head exhaust type1 , dbl plug - 47*38.5mm valves
Pauter 1:48 rockers new with bushing
Carillo Rod
Pauter Camshaft
Lifters T. Pieper 58 gram with bushings
Flywheel 215mm 914 2L ultra light
Helix clutch & dics 215mm
Porsche 930 Fans 226mm 11 blades
Pair of the throttle bodies TWM 50mm
This engine for my new old bug 1958
Cylinder T.Pierper Head just received .....
Re: Type 4 80*100 .... 2515cc
Posted: Sun Aug 24, 2014 9:11 am
by Electroman
sweet! I'm gonna be watching this.
question though. how much machine work do hose 911 cyls need to fit the type 4. I don't think I have actually seen anybody use them. I always though it could be a good idea, I see partial set selling cheep all the time.
Posted: Sat Aug 30, 2014 8:39 pm
Search for Wallys build... His 2.2L (100x66) with 911 jugs was making north of 450HP last I checked.
(I think it was sold to finance even more interesting things)
All else being equal I'd rather clearance machine aluminum vs iron any day.
Posted: Wed Sep 03, 2014 10:46 am
by Electroman
Pile I thought wally used a set of Nikkies for that build, the ones from his blown up 2.7. I thought he sold the 100mm 911 cyls. maybe I'm wrong.
Posted: Wed Sep 03, 2014 3:26 pm
He used the same 100mm jugs, just not as much, the bottoms took some damage from the dying rod but 66 stroke worked out OK.
Posted: Thu Sep 04, 2014 1:36 am
by Type 4 Unleashed
Electroman wrote:Pile I thought wally used a set of Nikkies for that build, the ones from his blown up 2.7. I thought he sold the 100mm 911 cyls. maybe I'm wrong.
I believe you are partially correct, I believe it was 100mm 911 Turbo pistons only he had and sold, the cyls he used in his 2.7 that were damaged when his rod let go were actually Type lV 103mm mahle/(Okrasa) alu-nikasil cylinders, (as Nickies are a Trademark of LN Engineering) that he had repaired by shorting them to remove the damaged section of the cyl's for the 2.2 Turbo motor.
Depending on the stroke and the head sealing issues, 911 cyl's could work as long as their the smaller bores, I would think.
Posted: Thu Sep 04, 2014 6:47 am
by Bruce.m
Oettinger, I thought
Posted: Thu Sep 04, 2014 9:07 am
by Type 4 Unleashed
Bruce.m wrote:Oettinger, I thought
Oettinger - Okrasa Is the same company. It's the year 1951: and it's the year the name OKRASA is introduced: Oettinger Automotive Specialty Institute.
And the Cyl's were made by Mahle, and the Crankshafts were made by ALFING Kessler
Posted: Thu Sep 04, 2014 2:31 pm
by coxcarrera
Picture of Frallan concerning this subject.
http://www.shoptalkforums.com/viewtopic ... 0&start=60
Re: Type 4 80*106 .... 2825cc
Posted: Fri May 06, 2016 3:02 pm
by coxcarrera
, 86*107mm sold
80*106
New engine specs :
Type 4 Case
106mm pistons J&E
106mm cylinder
Remmele Head exhaust type 1 50*42 Ti
Pauter Rod
Pauter Camshaft
Berg IDA 52mm New
Or Dellorto tri jet New
Posted: Sat Oct 06, 2018 11:53 pm
by coxcarrera
The comeback .......
