tonyorlo wrote:Got a question, the shop I took my heads to told me they are bus heads, should I ditch them in favor of 914 heads? The turbo should of help overcome some of the inefficiencies of the heads, but is it going to hurt me on power alot? I figure it would help with compression. They quoted me at $430 for a complete rebuild which doesn't sound bad to me at all.
They are also going to blast the case for me.
Now that the sites back up I can finally research it on here! They called me 2 weeks ago and Ive been dangling them along until I could come on here lol.
If they have the tiny valves you might consider upgrading, the bus heads tend to have been overheated many times and suffer badly from loose seats, do the bake and shake test to
make sure they don't fall out before spending anything on them. (the machine shop can probably do this for you)
...Heat to 400 then drop valves down on table, rattle with a hammer etc valves out of course, if the seats move or fall out they all need replaced, and bigger seats cost the same.
914 heads are not all that and usually need the seats replaced as well, and they crack easily, expensive to fix right.
You should consider bigger valves with new seats, and a porting job, the Bus heads can be ported to the same size as the 1.8 or 2L heads. Headflow Masters will still "do" bus heads, and Adrian knows T4 heads.
1.7L heads flow better than the bus heads with the same valves, and usually don't lose seats.
I'm strongly looking at building a heavily boosted 2.1L using 1700 heads with a modified head seal setup at the head outer surface (shortened jug tops 100x66)
