Vanagon housing + CS130D alternator install
Posted: Sat May 07, 2011 10:34 am
Picked up a Vanagon housing awhile back (Thanks, Don!) finally mounted it this weekend (my weekend is now Wed-Fri, every other Sat)
Also had the bright idea to install a new GM alternator on it, this one's a CS130D 105A for a 98 C/K pickup with a 5.7L.
Used a late Vanagon pulley, although the spacers etc are in a different order, it worked fine.
I'll probably redo the upper mount eventually, I built it for the late vanagon alt, the GM setup needs to be set back a tiny bit further.
The alternator has a 12V stud that sticks out the back, nice setup. Unfortunately it hits the tin. There is supposedly a "side post" version of this alt but it seems to be a custom thing.
I ended up making a CS130D "no-post" conversion, hooking 3X 10ga 8mm sealed crimps directly to the heatsink, 8mmx1.25 bolt ans a couple lockwashers for spacers (had to thin one down to clear a diode), the wires snake out through the snap-on cover. There's room for 2X~8ga, but I couldn't find any on short notice.
Here's the modified bus moustache bar I made up for my T4>T3 swap, added the outer Vanagon mounts using modified Bus mount brackets.
(Not needed for shroud, needed to prevent engine rocking)
Had the fan off to find an annoying oil leak, figured I'd take a pic.
