DEUTZ 912 CYLINDERS
Moderator: Type 4 Unleashed
petew
Re: DEUTZ 912 CYLINDERS
Post by petew » Tue May 22, 2018 8:40 am
Will these only fit in a type 4 case or could you also fit them into a type 1 case?
dstar5000
Post by dstar5000 » Tue May 22, 2018 4:24 pm
Type 1 cases cant accept a piston over 95mmm
CaliforniaMilleGhia
Post by CaliforniaMilleGhia » Tue May 22, 2018 7:29 pm
will 2 cylinders with no fins on the touching side give you more room than 95mm bore,
basically 95mm + sleeves touching each other .
I am not saying they will cool well , just asking if they will fit ?
Then you have to worry about head stud spacing or move the studs......
petew
Post by petew » Wed May 23, 2018 1:10 am
Right, thanks for the info. I'm personally impressed you can do this with diesel pots. I've been wondering for years if it would be possible to build a 2 stroke type 1 using motorbike pots/pistons and heads.
Steve Arndt
Post by Steve Arndt » Wed May 23, 2018 10:05 am
There is a build thread on here back in 2001 or so of a guy in the midwest that made a 2 stroke out of a bug engine. He also had a bus automatic trans mated to it in a drag sand rail. Pretty cool.
petew
Post by petew » Wed May 23, 2018 11:17 pm
Love to see a link to that!
Passatman
Post by Passatman » Sun May 27, 2018 2:34 pm
I don't think these can fit a t1 case. You could also fit them on a oxtboxer/wasser boxer case.
petew
Post by petew » Mon May 28, 2018 3:17 am
Isn't the bore spacing the same as Type 1 on Wasser cases?
sideshow
Post by sideshow » Mon May 28, 2018 9:53 am
Bore spacing is the same t1-wbx, head studs get moved on t1 when 4" bore or the like.
Post by Piledriver » Thu Aug 09, 2018 9:38 am
IIRC, the biggest bore for a t1 was 98mm, and it required siamesed cylinders (ARPM/autocraft iirc)
From memory this setup was for 100% alcohol burning sprint cars and had minimal cooling fins.
For a T1 to be driven, 94mm is about it.
