wbx crank in a type4??
Ok, I know it may sound silly, but... the 1.9 wbx crank has a 69mm stroke, counter balanced, very strong!!, type 1 big end rods with type4 pin ends. I dont know the length, but could this be used to give a lighter set of internals, a slight stroke increase (over 1.7) and some bigger bores??
Just wndered as I have a spare 1.9 wbx and may have a spare 1.7 type 4 (a tired one comes free with the good one).
Sorry for the stupid question!!
Si
Si
Without going into all the details, the type IV crank is bigger in overall size to fit a bigger engine case.
Chris
75 914 2.0L
72 1302s Super Beetle
71 Squareback
97 K2 Golf
Chris
75 914 2.0L
71 Squareback
97 K2 Golf
Ok, what are the main bearing sizes for a type4?? Iknow the wbx crank has different to a type 1 and I thought they were the same/similar to a type 4.. so the wbx crank may go in a type 4 case!!
It was just a thought!!!
Si
Si
- Dave_Darling
This has been covered a few times already.
I believe that the WBX is too short to go into a Type IV, by a significant amount. It might be able to go into a Type I? I forget...
--DD
--DD
The WBX crank can be fitted in a type 1 case with some machining for the bearings.
It will not fit into a type 4 case.
Paul.
Paul.
Ah.
So a wasserboxer is a ~$50 one piece (forged?) counterweigted 69mm type1 crank with type4 5 bolt flywheel attachment, so I can run a 228 mm flywheel, that I need to do a little machining on... perhaps already has T4 mains.(???)
Where am I wrong...Sounds too good to be true.
Perhaps my next motor will be a type1...
Things that make you go hmmmmmmm.
- stealth67vw
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Piledriver:
<B>Ah.
Things that make you go hmmmmmmm.</B><HR></BLOCKQUOTE>I don't believe they are counterweighted. They are also available in a 76mm stoke. I also don't think you will find one for $50, but you could get lucky. Prices tend to hover around $200 for a 76mm.
<B>Ah.
Is the 76 mm a factory unit, and if so, what did it come in?
The "wbx" has a very bad rep from the corrosion (heads) issues, and _bad_ motors are a dime a dozen.
Anyone know if these are or are not counterweighted?
Hmmm--Type1 bore spacing...
Could you put Subaru 16V heads on them???;-)
They are NOT counterweighted. The 228mm flywheel will only fit the 091 bus bellhousing. You could run a type 4 210mm or 215mm flywheel in a type 1 transaxle
The stock WBX 76mm crank was used in the 2.1 DJ and MV engines.
they are not counterweighted as such, but have more material between the conection of 1/3 bigend barrings and 2/4 bigend barrings
(The "wbx" has a very bad rep from the corrosion (heads) issues, and _bad_ motors are a dime a dozen.)
Because they dident do what VW recomended (they used the wrong anti-freez)
if you sort the small problems out there a good motor.
Here is the ShopTalk topic about wasserboxsers converted to aircooled :
http://shoptalkforums.com/bbs/NonCGI/Fo ... 01001.html
[This message has been edited by vwmorten (edited 05-05-2002).]
- Searoy
The WBX has Type 4 main bearing size with Type 1 spacing, Type 1 rods journals with a 69 or 76 crank (factory). It does have the 5 bolt Type-4-style crank end.
And the head studs have the 101.5 spacing, not the stock VW spacing, so Autocraft 101.5 heads, or similar race-ready heads with the wider bolt pattern, will bolt on.
WBX case (all aluminum), Type 4 bearings, Type 1 rods, 101.5 pistons, 90mm stroke, Angleflow heads, 2" exhaust, 8000 RPM... yup. 2913cc of fun. I need to calll my broker.
*** Teach a Man to Fish ***
Searoy
"I tend to lean toward a tighter gap and a
looser skirt....a little slap never hurt." -- Joe of the West
Searoy
James Lutz has 4" Century/Cima style iron barrels in stock and 4" Venolia pistons.
He also modifies C/E or S/E heads for the 4" wasser/Autocraft stud pattern! These are much more streetable than an AC-910 head.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Searoy:
<B>The WBX has Type 4 main bearing size with Type 1 spacing, Type 1 rods journals with a 69 or 76 crank (factory). It does have the 5 bolt Type-4-style crank end.
Now THAT'S the kind of information I wanted!!!
Thanks!
Since it is the T1 bore centers, that means the Subaru 16v heads might fittable.
Yum.
Thanks!
Yum.
